lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
Musturd
Even better. I’ll send you my address.
When are you taking the car out to make some passes? How’s the weather up there?
It’s nice out today . I’m going to do some data logs in a bit here . Saturday I gotta test and tune so hopefully it does ok
Musturd
Right on. I’m curious to see how it does.
I’ve got a test and tune I’m trying to hit tomorrow night.
It’s an airport so preps not the best and I still got 3.55’s on a 28” tire so it’s probably going to hurt the launch . Planning to leave 5500rpm . I didn’t wanna re gear the car before trying a 28’s most likely 3.90’s or possibly 4.10’s .
Hopefully you get some good passes in with the new upgrades .
Bronco2Fan
Texas
So, rained hard this weekend. Passenger rear soaked. Tore it apart again to find the problem. Went further than I usually do.
Found several reasons why. It appears someone or the dealer added sticky tape over some holes. I added some material to some little holes they missed or didn't think were leaking. You can see where I added and what the dealer did.
I found all the drain holes in the body. There's 4 on each side. Very well hidden. They are in the jacking points and 2 between them. You can tell them by the little bumps.
white95
Apex Junky
Admin
Prairieville, LA
Washed the Mustangs and the truck. Will hit the Lexus when the sun sets a little. Water is evaporating too fast right now.
Decided to strip the 18 year old window tint in the unicorn. Quickly realized my razor scraper was shit and the blade was practically serrated.
Made a quick trip to Vatozone for some fresh blades but bought a long handled scraper instead. Should’ve been using that from the start.
Musturd
I replaced the coil with msd blaster ss coil , pulled the plugs and tightened the gap up up to .20 added some the tune with extra timing and nut and bolt checked the car front to back . Once the weather is nicer I’ll take the car for a burn and data log
RAU03MACH
NEW MEXICO
Started the 95 a few minutes ago
But the wind picking up
Tomorrow 40 mph winds
Fucking wind trumps all
