Bronco2Fan
Texas
I know. NPD still shows they have some, but only in parchment. I can see why. Not everyone likes parchment and usually most folks add a black carpet in.
But it laid down easily and all the holes were ready to go. The bag the carpet came in had a 3/23/02 date on it, so it's been sitting a while.
Do you happen to have the stock number handy?
Musturd
Seems right . I’m taking my grey carpet out for a black one .
Mustang5L5
M-013000-125Q
It's listed as convertible, but when you buy ACC carpet they list the coupe/convertible application to be the same so not sure how significant the differences would be.
That things a bad ass unit
It's a shitbox, but it is a cool shitbox. Rearend is currently thinking about unaliving itself, had some fluid blown out the vent and a bit of noise on the ride home. But we gonna rock this night ride before we tear into it.
Musturd
Most hard core wheeling rigs are shit box’s but they’re always a ton of fun . My friends jeeps the same way . Calls it a shit box but it goes anywhere
Musturd
Registered for the drag and driven in June . Long list of shit to get done before then .
I just got done actually running the wiring for the rock/pod lights correctly. Got 1 more hole to drill and a rivnut to install and then it's just waiting until the last two pods show up so I can finish the install.
I might actually be ready before the day of a ride.
cobrajeff96
Germany
Well, I was back at it again with the ongoing power steering saga that's been going on for four months now. Long story short, burned up two re-manufactured Ford pumps, two brand new Ford pumps... and so I tried a different route now after doing some research into the GM Type II pumps. Broadest consensus out there among vendors/experts is that Ford pumps just suck. GM pumps are more ubiquitous, can be highly customized, and generally work better and are what serious racers and off-roaders use. So I made the investment with a custom-valved pump and a custom pulley, and I spent the last day or so putting in the sweat to mock everything up and fabricate new lines/adapters to make it all fit. System is primed and ready, so hopefully tomorrow during testing it just finally works!
1/2
cobrajeff96
Germany
2/2
weendoggy
1/2
I've been running a Type II on my Cobra for 15yrs. Best pump ever! I also use a Heidt's valve to control flow because I had it on when I first built it in '99 with the stock Ford POS to lower pressure. Did you make a custom bracket to mount it to the Coyote, or is one available. If my stock '02 pump takes a crap, I may switch.
badass98svt
I’ve built quite a few diffs, and I don’t quite understand how this happens. I would imagine the pinion bearings would be destroyed letting the pinion gear move that far.
From what I remember (happened probably close to 20 years ago), mine started as a bad pinion seal that I ignored. Looked way worse than the one in the pic though.
I saved the diff for years as a conversation piece :D
jd96gt
