I translated your post into 'MuricanIt's been busy so got to change the battery today.
Yuasa YBX3113 is just under 7 inches from bottom to top of the posts.
It was a direct fit and left 1/2" - 3/4" room to inside of the hood.
Woohoo, got it off! A night soaking in WD40, a few gentle whacks from a small hammer and got it moving with a big wrench.Tried replacing the EGR valve. Failed at removing the nut from the pipe. It's in such an awkward place, it's difficult to put force on the wrench. Gonna give the penetrating oil a day to creep in and then will try again tomorrow.
(Any advice or tips are more than welcome)
I was very satisfied with the Yuasa I put in my Harley a while back. No longer have the bike, but I bet the battery is still good!It's been busy so got to change the battery today.
Yuasa YBX3113 is 175 mm from bottom to top of the posts.
It was a direct fit and left 15...20 mm room to inside of the hood.
Shit man, I wish you said this two weeks ago. I just tossed mine. That said I put MRT hood struts on which are cheap and super easy to install. That would also solve your problem.Anyone have a spare bolt for the hood prop rod? Or a part number or even a size and thread pitch? Should be the same for all sn95’s otherwise it’s for my 03.
Those are 6mm x 16mm and 1.0 pitch. They are a common body panel thread pitch for the cars. However, that is a 8mm hex head where most others are 10mm hex, but they all work. Make sure of the length because it needs to penetrate the threaded clip.Anyone have a spare bolt for the hood prop rod? Or a part number or even a size and thread pitch? Should be the same for all sn95’s otherwise it’s for my 03.
Some nice offset wrenches would helpTried replacing the EGR valve. Failed at removing the nut from the pipe. It's in such an awkward place, it's difficult to put force on the wrench. Gonna give the penetrating oil a day to creep in and then will try again tomorrow.
I was thinking about that but I’m trying to do this as frugally as possible for the moment lol. Thanks for the suggestion!Shit man, I wish you said this two weeks ago. I just tossed mine. That said I put MRT hood struts on which are cheap and super easy to install. That would also solve your problem.
Is the core support not threaded?Those are 6mm x 16mm and 1.0 pitch. They are a common body panel thread pitch for the cars. However, that is a 8mm hex head where most others are 10mm hex, but they all work. Make sure of the length because it needs to penetrate the threaded clip.
I might, off my ‘95 Cobra. I removed the hood prop rad for shocks and may still have. I’ll check later and let you knowAnyone have a spare bolt for the hood prop rod? Or a part number or even a size and thread pitch? Should be the same for all sn95’s otherwise it’s for my 03.
think I found it… look right? 8mm headAnyone have a spare bolt for the hood prop rod? Or a part number or even a size and thread pitch? Should be the same for all sn95’s otherwise it’s for my 03.
Yep that’s it! Ok so it does have one of those threaded clips.I might, off my ‘95 Cobra. I removed the hood prop rad for shocks and may still have. I’ll check later and let you know
View attachment 35942View attachment 35942
