Car looks right tho! Beautiful!
Yeah? Prove it!Got said tyres fitted
TMW
There's no tyre at all! You goin' barefoot?
New 7" wheels.There's no tyre at all! You goin' barefoot?
It is truly a PITA job, as I just did it right before I sold the car. I had to use a 15mm box end wrench on the tensioner too - but I "cheated" and used another wrench hooked on the open end to get additional leverage.Replaced the voltage regulator on the alternator. Now the charging voltage at idle is down from the previous 14,8 volts to 14,3.
I hope this might solve my audio amp turn on issue... I'll test it tomorrow.
On a sidenote: removal of the alternator was a pita. First of all the belt tensioner was super difficult to release because the coolant reservoir is very close to the tensioner and I couldn't fit any of my ratchets on the bolt. I had to do it with a 15mm box wrench, but it was not too long and was very difficult to turn and hold it.
Second, the long bolt on the bottom right of the alternator which goes through the bracket was also difficult to get out because the upper radiator hose was in the way.
How do you guys do this job? Do you have a special wrench / bar for the tensioner? Or do you remove the coolant reservoir?
It's a '94 5.0. I think this is way easier on the 4.6 because of the different location of the pulleys.
Have you thought of using the small Battery Tenders? I use one on my Cobra and have it hard-wired to allow me to just plug it in. Small size Tender Jr. the size of a small transformer. Use one on my portable generator too, although now I don't need it due to my Generac installed one.
I meant I don't need my charger for my "old" portable 12kw generator. I just installed a Generac and it does do it's test cycle every couple of weeks. With that tied into my solar I don't have to get the portable hooked up. I can sit on my ass and know it's there.my Generac has a self charging system on it
Just remember to unplug it before you take off.i need to pick one up
