Highlighted posts from Wednesday, Mar. 02, 2022
SN95Newsletter
Click here to view on the web
Highlighted posts
March 01, 2022 * 15 posts * 75 views
Zacharoo03 said: Hi, I performed the PI intake manifold swap a couple months ago. Everything is working great, except my fuel economy. I know it was going to go down SLIGHTLY, but even on the highway ... Read more >>
March 01, 2022 * 27 posts * 291 views
ttocs said: if it were me I would probably go with the dual split 45 degree cut ends. Tony did it on his car they look killer imo. Read more >>
March 01, 2022 * 19 posts * 207 views
Daryl said: Pulley arrived (late in the day of course). Pulled belt off and installed new pulley and accompanying washer. New pulley's diameter less than old one. After removal of the old ... Read more >>
March 01, 2022 * 34 posts * 301 views
Frank.JD.Perez said: honestly tube chassis might be safer... you can reinforce better than factory, and if you crash its an easy replacement Read more >>
March 01, 2022 * 9 posts * 128 views
jpg98 said: I need to do the same job. The PO put a cobra badge on my GT and I'd like to switch it back to the horse. Read more >>
March 02, 2022 * 1 post * 9 views
ttocs said: I found a set for two complete doors with panels/cranks that is kind of local to me and I know someone that is looking for just the door panels. I do not need two doors sitting ... Read more >>
March 02, 2022 * 1 post * 7 views
SN95Newsletter said: Click here to view on the web Highlighted posts The Spark Plug Dilemma February 28, 2022 * 14 posts * 113 views 96-04 - 2V Specific Just picked up this beauty with 7k miles February ... Read more >>
March 02, 2022 * 43 posts * 510 views
J_lope82 said: CJ pony parts has them but I changed my mind I went back to 3/4" because I wasn't sure I would like the tire sticking out that far. Read more >>
March 02, 2022 * 4 posts * 107 views
99VertStang said: cool...I'm in Miami but have friends and family in Tampa Brandon valrico Riverview areas....can you send me pics of what you have I'd pick it up so no shipping needed. Read more >>
March 02, 2022 * 8 posts * 690 views
ttocs said: are you sure its the rear main? I thought mine was until I was able get under it with the trans out and then I could see the oil trail went up to the top/back of the lower intake. ... Read more >>
Continue reading...
TylerGT
