No start hot. Has spark. has fuel *solved*
Canner
1997 mustang GT stock except for bbk intake.
The starts and runs great cold. As the temp comes up it stays to surge and full warmed up it will buck and surge under throttle.
Once warmed up it won’t start again for 3-4 hours. Has to be full cooled off to start. It will crank over fast but won’t fire.
Tested 40 psi fuel pressure cold and hot cranking.
Pulled a couple different spark plugs and cranked with them out, they have spark.
Crank and cam sensors replaced.
Not sure what to check next.
Any advice would be appreciated
Bronco2Fan
Texas
Have you checked the TPS? Mine would get hot and stall on me if I wasn't in the throttle. Clutch in and coasting, stall. Pop the Clutch and restart easily. Just a guess
Canner
Canner
Yeah worth a shot. I test it tomorrow hot and cold
thanks.
GTamas
Austria
Glad you got it solved!
For my education, why does a faulty coolant temp sensor cause this issue?
highplace11
Essentially long story short... The ECU (TUNE) uses coolant temp to modify everything from SPARK TIMING, FUEL TRIMS, IDLE AIR CONTROL VALVE, ETC to work its magic... With it likely reading cold the entire time it eventually just runs like CRAP after warming up BUT it also surprises me some that it would cause a NO START situation warm...
I'd like to know why the OP didn't notice the coolant gauge never came up and suspect an issue would be my first inquiry...
God Bless, and HOTROD HARD... Never let anyone discourage you, we are a special breed of people with our Mustangs... ;)
highplace11
Canner
Canner
highplace11
There are two temp sensors. The gauge is controlled by the other one. So the gauge read as normal.
depending on the temp it sets the IAC at certain % open and controls fuel, ect while cranking. If it had bad data then it was set up to fail.
lwarrior1016
Mr. Secondary Timing Chain
South Mississippi
It’s also likely the temp sensor read over temp after it got hot and wouldn’t let you start it back up because it thought you were trying to melt the engine down.
