New valve cover gasket and power steering pump in the XJ, got the bracket welded up for the WJ. Productive day for once… now if I could just get my mower fixed.
Adam.z.g
Installed maximum motorsports extreme duty rear control arms and new stock uppers. Had some cheap aftermarket upper and lower arms already. Finishing the coilover install in the next few days. This winter I’ll crack into the Panhard bar and tourqe arm boxes IMG_7296.jpegIMG_7297.jpegIMG_7298.jpeg
Daryl
SoCal
Cursed at it… Repeatedly! Having no fun installing the water temp gauge. Crappy installation instructions don’t help someone like me with little to NO electrical knowledge. Errrrrgh!
Musturd
It’s really easy . Check YouTube for some how to’s
Daryl
SoCal
Here’s why:
1. My lack of electrical knowledge: there’s a huge and a black wire on the back of the gauge. Which is power? Which is ground? And where do I attach them to?
2. Where is safe to drill a 7/8” hole? Or, if I don’t drill, where’s the main bunch of wires that ttocs mentioned there’s enough room to fit the gauges cable could fit through?
The YouTube videos I found didn’t answer these questions
joemomma
Not familiar with the gauge install, but what in the world in it needs a nearly 1" hole?
Daryl
SoCal
The grommet that goes in the firewall. If Opal95 and ttocs idea work, I wouldn’t need to drill a hole
joemomma
Right on. Were it me, I'd just go slightly larger than the cable needs and find a suitable size grommet if you can't find the spot they mentioned.
Daryl
SoCal
A viable option but unfortunately there’s the coupler for the probe already on the cable, so the hole has to be big enough for it to pass through
joemomma
Ahh, I see said the blind man! Makes sense now.
cobrajeff96
Germany
Did a thing (or two) today...
Terminated some 4awg leads from the lithium starting battery and the lead main battery to the battery combiner (voltage sensing relay / automatic charging relay) so that the lithium will charge only when necessary and then promptly disconnect itself thereafter. Prevents either battery from draining the other as well as prevents splitting the amperage between the two for too long.
Also fashioned some steel bracketry for a stabilization mount, bracing the engine oil cooler and the power steering cooler to the lower radiator core support. Can't see it but I got some thick rubber pads that go under and over the side attaching to the cooler frames. Even managed to counter sink the holes drilled in the bracket that lighten up the weight. Don't look too shabby now. Off to the powder coater we go!
Rascal28950
