98mstanggt
If i was to spend 11k it would be definately F/I............. This my Setupcaseypayne69 said:DropTopPony said:I was at 285rwhp through my auto N/A a few years back.
I was running VT st2 heads and Comp 270ah cams on a stock NPI shortblock. Steeda Pullies, dynomax shorts/basanni x pipe/borla catback/ C&L plenum & CAI/ BBK 75mm TB/ Livewires ignition-wire setup/ denso iridium plugs and a bunch of other crap...with a SCT tune.
Want over 300 rwhp in a laughable manner and got money? Buy this......
FRPP heads, $800 a piece, get them ported What another $900?
A Medium range Comp cam, not to aggressive $600
BIG BORE Short block, $4,500
P-51 Intake With an adapter for the FRPP heads $1,200
Parts $7,950 bucks not including more parts to do the job right. And the port work and other labor is probably another $2,000. So for $9,950 bucks, will say $11,000 k all said and done. You can have over EASY 350rwhp Hell 400 RWHP with that combo tuned right.
Ported Pi heads
Pi Intake(for now)
274h Comp Cams
Beehive Springs
Mac Long tube Headers
Mac off h pipe
Flowmaster Cat back
2400 Tci Stall Converter
24lb injectors
190lph Fuel pump
9mm wires
Msd Coil Packs
BBk Cold Air Intake
75mm t/b w upper plenum
Ud pulleys
Sct x3 tune
3.73 gears
31 axles/diff
Ima start upgrading internals and suspension next.......... Im use the stock block just get it bored and add new pistons, rods, etc
